• Thread starter Paul2468
  • Start date
  • Replies 29
  • Views 5K
Discuss Kickboards in the Tiling on Underfloor Heating area at TilersForums.com.
Paul2468
Hi, i wonder if anyone has had issues with underfloor heating escaping from area by kickboards, where the tile is cut to feet of units?
Thanks in advance
Paul2468
No not under units the kitchen was in place before tiling so could only tile to feet of units. So wondered as cable close to an exposed edge heat could be escaping out the side of tile, yes floor is heating up ok, issue is where kickboards are not as warm as rest of floor.
Did u see the cable laid into the matting?
Sounds like it hasn't been taken close enough to the edge.
Insulation boards, in an ideal situation, would be laid on a screed to prevent heat being radiated downward.
J Sid
As @3_fall said, screed is probably heating up and he's is migrating.
I haven't used this heating system but would have thought a insulation board should have been used.
Measure the screed temperature under the units if you can.
And how far away is the cold spot?
Is that what Schluter specify, 75mm
Personally probably would have taken it closer.
Reply to Kickboards in the Tiling on Underfloor Heating area at TilersForums.com
