Discuss Looking to remove tiles in Bathroom (need advice) in the DIY Tiling Forum area at TilersForums.com.
Romelee
Points
158
Dorset
Hi,
Many thanks for all the tips acaciaguy, just a few more things.
Any idea of what size tile backer boards i will need?
Best and cheapest place to buy all this?
What tape will i need to cover the joints?
Does anything need to cover the tape?...i.e plaster?
What's the best screws for the tile back boards?
How to cut the tile backer boards, same as plaster board?
Sorry for all of the questions
Jay
Romelee
Points
158
Dorset
Thanks for that link, so far i think i need:
10mm thick boards minimum (need to check what thickness boards are up at the moment)
Self-adhesive alkaline resistant tape
PCS Zinc plated screw with 35mm Galvanised Washer, For use with Delta Boards
Jay
Romelee
Points
158
Dorset
Also found this info:
FIXING TO STUD PARTITION WALLS
6mm boards are not suitable for fixing to stud walls. For 10mm and 12.5mm thick boards, vertical studs should be set at *300mm centres. For board thickness
of 20mm and above * 400mm centres are suitable. All board edges must be supported by timber noggins and fixed using approximately 15 fixings for a
1200mm x 600mm board or 27 fixings for a 2400mm x 600mm board. PCS 35mm diameter washers must be used under the head of a steel screw
. Screw
down until the washer bites into the board. Tape all joints using a self-adhesive alkaline resistant tape or suitable waterproofing joint sealing system. (* Stud
centres should be set subject to load requirement)
TILE FIXING TO WALLS
Once the adhesive for securing the boards has hardened and all joints have been covered with an alkaline resistant tape or suitable waterproofing joint
system, tiles can then be fixed directly to the board surface.
Romelee
Points
158
Dorset
248x398 tile size sounds like BCT (British Ceramic Tile) - many tilers would advise against this brand due to quality issues.
Yeah you are spot on, that is the brand i was going for "Brighton Linear Grey wall tile by British Ceramic Tile" now i am back to square one of finding tiles at a decent price:oops:
Romelee
Points
158
Dorset
They are a decent price.
Just not a decent quality . . . .
Can you recommend a place that do decent quality tiles at a reasonable price, i would not mind buying expensive tiles but this is not my home, it's council owned and i am just decorating it room by room to make it a better home.
All the best
Jay
Boggs
Points
1,118
Uk
If you go with the Brighton tiles remember to add 30-40% more to allow for glaze faults, chipped edges and completely different sized tiles I’m talking 2-3mm.
I fit a fair few BCT tiles, they are not all bad but these ones will be.
Keep back all the bad ones and get a refund from where you buy them from.
Reply to Looking to remove tiles in Bathroom (need advice) in the DIY Tiling Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
