Discuss Looking to remove tiles in Bathroom (need advice) in the DIY Tiling Forum area at TilersForums.com.
Romelee
158
Dorset
Even better :grinning: If its one layer of plasterboard then I would take it all off with the tiles and replace the shower / wet area with a backer board and then the rest of the plasterboard areas use moisture resistant PB.
Ain't checked yet but what if it is more than one layer, how does it change things? would i have to replace it with two layers of tile backer boards?
Jay
acaciaguy
558
Warwickshire
I'm doing a rip out and replace job at the moment following water damage in a flat. I have taken the wall back to studs but I have to reboard one wall with sound board as it's a stud wall separating two flats. I will then overboard with backer board and the rest of the walls will be just backerboard (due to weight of tiles)
Romelee
158
Dorset
Hi,
Many thanks for all the tips acaciaguy, just a few more things.
Any idea of what size tile backer boards i will need?
Best and cheapest place to buy all this?
What tape will i need to cover the joints?
Does anything need to cover the tape?...i.e plaster?
What's the best screws for the tile back boards?
How to cut the tile backer boards, same as plaster board?
Sorry for all of the questions
Jay
Romelee
158
Dorset
Thanks for that link, so far i think i need:
10mm thick boards minimum (need to check what thickness boards are up at the moment)
Self-adhesive alkaline resistant tape
PCS Zinc plated screw with 35mm Galvanised Washer, For use with Delta Boards
Jay
Romelee
158
Dorset
Also found this info:
FIXING TO STUD PARTITION WALLS
6mm boards are not suitable for fixing to stud walls. For 10mm and 12.5mm thick boards, vertical studs should be set at *300mm centres. For board thickness
of 20mm and above * 400mm centres are suitable. All board edges must be supported by timber noggins and fixed using approximately 15 fixings for a
1200mm x 600mm board or 27 fixings for a 2400mm x 600mm board. PCS 35mm diameter washers must be used under the head of a steel screw
. Screw
down until the washer bites into the board. Tape all joints using a self-adhesive alkaline resistant tape or suitable waterproofing joint sealing system. (* Stud
centres should be set subject to load requirement)
TILE FIXING TO WALLS
Once the adhesive for securing the boards has hardened and all joints have been covered with an alkaline resistant tape or suitable waterproofing joint
system, tiles can then be fixed directly to the board surface.
Reply to Looking to remove tiles in Bathroom (need advice) in the DIY Tiling Forum area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
