Discuss NoMorePly to new floor for Tiling - fixing advice in the America Tile Forum area at TilersForums.com.
ShaunH
Points
11
England
Hi all, I want to tile over a completely new floor. New floor joists have been installed with new 22mm flooring sheets over.
I’m thinking I need to install 6mm NoMorePly then tile.
I’m assuming the following: -
1) PU adhesive and cement screw fixing for the NoMorePly?
2) primer NoMorePly?
3) lay tiles using flexible adhesive?
Or could I just
1) screw down NoMorePly (no adhesive)
2) no primer, just lay floor tiles on top?
The two small rooms are approx 2.5m2
Thanks all!
Points
63
Staffordshire
So, the sbr primes and seals the timber substrate, and the matting effectively acts as a flexible substrate over the floor, so if there's movement in the timber subfloor it should be absorbed by the matting. It is the best option by far. You can put tile backer boards down, like hardie backer, some new builders use it, but I've been back to a few doing remedial where there's been movement and grout joints have cracked and occasionally tiles debonded. If you use matting allow for 5mm, that's about 3mm for matting and a couple of mm for adhesive.you can sbr the timber and tile straight on it but I'd only advise that if you haven't got the height to use matting.
ShaunH
Points
11
England
Thanks for the info thank you! Much appreciated.
If you can indulge me, would this work; using thin plywood over the 22mm boards, “plenty of nails”, unibond then tile?
Points
38
Devon uk
I used a lot of products from STS who manufacture no more ply etc. the advice they give around their product range has been invaluable and they generally have something for everything. I wanted to install UFH on an upstairs floor which is joisted and there cement boards , adhesive , tanking solutions, shower back boards, all worked a treat and the tiled floor is perfect!
(Admin edit; removed email as it might spammed on here use the forum private conversations to share deets)
Reply to NoMorePly to new floor for Tiling - fixing advice in the America Tile Forum area at TilersForums.com
