Discuss outside corner in rectangle bathroom in the DIY Tiling Forum area at TilersForums.com.
mr angry
hi guys,
when you say trim on top of tile, what do you mean? is this a separate trim from the coving and what does it look like? where can i buy this trim from?
cheers
mr angry
it looks like my floor has a slope of 1" from door to window. not sure how i missed that but im guessing its because i didnt use a batten at the time with my level :/
anyways can i use cement or mortar to bring the level up and screed the floor? im not sure how much stuff i will need but can i mix sand and cement as a base before i start tiling the floor?
please recommend what type of stuff to buy before i buy the wrong stuff :)
ive not had much time to do the bathroom lately so its just when i have time thats why it seems to be taking forever!
cheers
mr angry
hi guys,
been busy lately so the bathroom was put on back burner. i have since finished the tiling but i still have the issue with the coving at top. in a previous post someone mentioned a trim on the coving. can someone describe what this is?
i know someone also mentioned about using new coving over old coving....will i have any trouble keeping the old coving in place? the coving already installed, measures at 110mm, what size do you recommend to cover old coving?
here are some photos of the tiling so far... and yes, the tiles still need cleaning up lol. also the tiles you see at left hand side which look off, is an actual access point/hatch and i need to cut a hole for the drainage too :)
thanks in advance!
thumbnail_IMG_20181119_124517.jpg thumbnail_IMG_20181119_124522.jpg thumbnail_IMG_20181119_124527.jpg
J Sid
I'd remove old coving and tile a bit higher then have new coving fixed over tile and to cover damage ceiling from removal of old coving.
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
New posts
Reply to outside corner in rectangle bathroom in the DIY Tiling Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
