Discuss Priming Anhydrite screed in the Canada Tile Advice area at TilersForums.com.
DHThompson
Hi folks,
I’m just about to start tiling the ground floor of my house with Limestone tiles, the area is around 80m2. The floor has a anhydride screed which I have recently sanded and hoovered. I planned to prime the area with neat ROCATEX acrylic primer twice before I lay my decoupling mat. I ran out of ROCATEX after the first application so (stupidly) added a PVA water mix (3:1) to do the second coat. Can anyone advise if this will cause problems, and if so how I can remove the PVA?
F
Flintstone
Not good !
I would say your gonna need to sand the screed down and start again. A few questions.
Is it heated ?
Is it dry ?
Has it been sanded ?
Are you uncoupling ?
What adhesive are you using ?
Reply to Priming Anhydrite screed in the Canada Tile Advice area at TilersForums.com
