Discuss Rubi Tc 180 circular saw in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
Rick-o
Points
518
Guernsey C.I
Afternoon all,
Has anyone ever used the above cutter. It can be used with a guide rail that will fit a 1200 tile which I seem to use more and more and looks to be a handy piece of kit if you have limited space to store a wet cutter.
Rick
Yeah I've had one few years.
I can't answer now but, if you use search box above and enter my username as author and relevant key words you should find a few very in depth posts about it.
A few members have bought on the strength of those reviews and are very happy.
would you still buy tc180 or would use the kerra cut with grinder attachment as I think you have used both systems . Please correct me if I'm wrong
No, you are not wrong, I have used both.
They both have their uses of course, if your main material was standard porcelain, then the TC would be my choice.
If ex large format or thin tile was your main material, then the Kera Cut would be my choice.
Thin porcelain does not wet cut well.
The speed of wet machines is too slow in the main.
Lou
Admin
Staff member
Points
1,473
Staffordshire
Reply to Rubi Tc 180 circular saw in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
