Discuss Should i use ditra mat over polypipe plus overlay boards? in the America Tile Forum area at TilersForums.com.
Hi. Need some advice.
I've laid down polypipe plus overlay boards in my house.
My tiler says we should place a ditra mat before laying tiles.
However, polypipe say we should NOT use a ditra mat as it will prevent the tile adhesive from curing.
Dont know what to do. Any advice from tilers / homeowners / plumbers who have used the Polypipe Plus Overlay system for UFH would be appreciated. Thanks
Dave
Staff member
Subscribed
389,894
1,000,000
Co.Durham
Tile adhesive ( cement based ) cures by chemical hydration. So cannot see how that argument works lol. As for using it over that system, I’ve personally not come across it. Tbh from what I’ve read on here , most tile directly to the system. Ditra would be belt and braces , something I always believe in but to be sure call schluter uk tech line and ask if it’s ok over poly pipe overlay system.
Reply to Should i use ditra mat over polypipe plus overlay boards? in the America Tile Forum area at TilersForums.com
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
