Gooner
First post. Amazing forum for tiling info.
I have a question about fitting 12mm aluminium tile trim. I've searched the forum, but haven't found exactly what I am after.
I'm halfway through my tiling job and am up to the point where I need to work out how to tile some external corners. I have several "niches" I have built into the wall studs. E.g. I have a shelf in the shower that I need tile.
My current plan is to use polished aluminium tile trim on the niches. I have mitred the the tile trim to 45 degrees quite accurately, but I believe that unless it is absolutely perfect (which is not practically achievable), there will always be some sharp edges that will be difficult to eliminate regardless of how careful I mitre and place the trim. (I don't want to be cutting myself against sharp trim while showering!)
The other alternative is to cut the tiles with a 45 degree bevel at the external corner edges and not use tile trim at all. I can do this using my diamond disk tile cutter as the bed is able to be tilted at a 45 degree angle. However, it is difficult to cut the tile with a 45 degree bevel without chipping the sharp corner on a glazed ceramic tile. Also I fear that the sharp edge may be damaged easily even once grout is applied between the edges.
Any suggestions or hints would be greatly appreciated. I have attached an image where I have slighlty misaligned the trim to illustrate the point I am making about the sharp edges. The tiles are 600x300 and around 12mm thick.
