Discuss Tiling onto Ply, can it be a success? in the DIY Tiling Forum area at TilersForums.com.
Wayne Brown
Points
548
Norfolk
6mm for me with those mats for full coverage.
Am I reading this right, you have put ply over an anhydrite screed with ufh?
I thought that bud why fit ply over the screed ? It is such a poor conductor of heat and is a laminated product any moisture in there will result in failure of the floor there are far better options. Kop
AD1
Points
36
Hartlepool
The Screed is between the joists and not load bearing. It is supported by the insulation underneath. The 18mm ply is the structural load bearing floor and although it does insulate, it doesn't make the system ineffective and requires the flow rate to be slightly higher than a screed floor.
After living with it for a year I can say I'm impressed with the efficiency and performance and I must say I was sceptical before installing it.
On one
Somewhere along the line it sound like you are going to have an edge of your 18mm plywood that won't be mechanical fixed down to the joists(in between the joists) Ditra will only accommodate lateral movement, not vertical movement.
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
Reply to Tiling onto Ply, can it be a success? in the DIY Tiling Forum area at TilersForums.com
