Discuss Trowel size advice in the Canada Tile Advice area at TilersForums.com.
If you haven't done much tiling before this you might be better using a standard set...or a fast set with a longer open time. With fast set you have more chance of lippage (tiles different heights) as the adhesive is getting thicker all the time in the bucket. If you don't need to walk on the floor straight away you don't really need fast set.
Thanks for ur help I have allready purchased now unfortunately
having what u said I’m thinking of swapping the adhesive to the keraflex maxi is states 24 hours to grount which I can live with but also states 14 days in fitting The kitchen on day 3 do u think that will be a problem
Reply to Trowel size advice in the Canada Tile Advice area at TilersForums.com
  • Question
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
