Discuss Undulating freshly laid ply floor? Products to screed ? in the UK Tiling Forum area at TilersForums.com.
Mike Mike
Not my choice! It's a small area where two tables will go to break up the karndean.
What ply do you advise ? Would you advise to screed ? What complications could arise ?
Tell the client they would be 200 times better off just smoothing out the ply with some Uzin NC 181 and then sticking more Karndean down. Ply needs to be 15mm (British Standard) which doesn't exist, so 18mm. SLC how thick? 15mm? With reinforcing mesh (Swedish standard, don't know British). Plus height of slate, 10mm, plus 4mm adhesive. How much higher is this area going to end up than the rest of the floor????
If they want to break up the Karndean just get some more Karndean in a different colour/style :lol:
Gazzer
Really ?...who would have thought it didnt exist ?
http://www.james-chambers.co.uk/she...w-b-p-plywood/w-b-p-eterior-plywood-1229.html
Mike Mike
Ermmmm thats quite cheap actually for Ply...its well overpriced .
I was thinking the same thing, was just looking at prices of all sheet materials. OSB is 31.5% dearer on your site than here.
OSB 3 NEXFOR 11X1200X2440MM - OSB - Skivmaterial - Byggmaterial - Webshop
I suppose the falling value of Sterling means prices of imported materials from Scandinavia are rising, but given the differences in VAT prices and the fact we get ripped off on everything, I would have expected it cheaper in England.
Reply to Undulating freshly laid ply floor? Products to screed ? in the UK Tiling Forum area at TilersForums.com
Good morning all. After a little advice. I'll post pictures a bit later. However.... The homeowner of the property I'm working on has just come to me and asked if anything can be done about...
  • Question
  • Question
Bathroom floor. I would be grateful for advice on how to prepare my bathroom sub floor ready for tiling.I have removed the floor boards and plan to lay 18mm WBP plywood.The question is, what...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Sticky
  • Question
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few ways to fix tile to bathroom walls. First you need to prepare the walls for tiling. Note that...
