Discuss Which tile adhesive to use with Schluter Ditra in the Tile Adhesive / Grout Advice area at TilersForums.com.
Thank you for posting the result of your enquiry, so often we’re left wondering the outcome.
You do realise several hundred tilers just breathed a sigh of relief! 😁
thank you.
Dillygaff
Hi , what reason are you using Ditra for firstly and as for adhesive, yes your info is American based , schluter uk say modified adhesive is fine.
Apparently its flexible for laying the ditra and standard for fixing the tiles as the ditra is designed to take the movement and the tiles are set on the dovetail of the matting. Makes sense to me I'm not a tiler. ?
Chris1
schluter states when sticking ditra to concrete use a unmodified adhesive and when using ditra on top of plywood use MODIFIED
Y
Yammar
Hi and thanks for the reply. I'm aware of how to install the Ditra and what trowel to use, what I am unsure of is which tile adhesive to use. Have you used flexible adhesive or polymer modified to install tiles on top of Ditra? As the previous posts explain Shluter don't recommend using a modified mortar. Thanks again for your input.
Lou
Admin
Staff member
Points
1,473
Staffordshire
Reply to Which tile adhesive to use with Schluter Ditra in the Tile Adhesive / Grout Advice area at TilersForums.com
