shower waste over joist
janzbro
As per my sig the shower waste lays directly over the joist(sods law eh)
Anyhow, is it ok to chop away part of the joist or do I need to strengthen it some how
there are rules and regs for notching joists but from what you see nobody adheres to them. Common sense usually prevails, I usually overkill and put noggins in if i 'notch big'!
no, front right (1200 x 900 rectangle) cant turn it as access would be impossible due to other beams and to tight in corner even if I could
Thats what i was gunna suggest it spin it..mmmm not a luver of chopping joists but it can be done if you strengthen properly..
nogins running between cut joist and next or either side ?
and what size (same as joist )
its an 8" joist btw and I'll need to remove 5"
cant the tray be moved away from the wall a couple of inches to clear it ,then ply the gap? or have i got the wrong end of the stick:smilewinkgrin:,steve
There's no way I would want to chop 5" off an 8" joist, it's way beyond anything I've ever seen or done, why so much, shower waste is only 30 - 40 mm ish and as has been asked, what pipe are you using, are you putting in a trap ? I think a rethink is needed mate, can you do a quick sketch showing layout etc
Tags Tags
shower usa
janzbro,
Alan.P,
janzbro,
Alan.P,
