re-instating a floor
Thanks Al, much appreciated.
Would it take off the adhesive residue back to the concrete floor. Then if the new tenant wants to paint the floor its ready for them.
Hi Dom. Yes it will do that but it might leave it a little rough for painting. If you want a surface for painting you might be better off with a carborundum block sander. I trying to find one online and will post a link when I find it.
dom
i might be too late but just rang mapei and they recommend a product called..
ultra top ..it needs to be laid at a minimum of 10mm and its a finished surface product that can be painted and used in warehouses with standards sized fork lift trucks
they also do a range of finished paints for the floor under the name I 24..
sorry its a bit late mate ..
ed
Thanks Ed, much appreciated pal.
After speaking to technical they reckon I would need 300 plus bags for 160 sq mts, that would cost £5600 and then my labour on top, its not feasible to be honest. 1.5 kilos per square metre gives 1mm build up and they recommend 10mm minimum for fork lift trucks, so that would be 15 kilos per metre.
Much appreciated guys.
:thumbsup::thumbsup:
