Setting out multiple rooms advice
infidel
Done plenty of floors, but never done any multiple rooms yet.
Can anyone give me some pointers & advice how to go about it.
Do I just find a line down the lenghth of hallway then 90 degrees off into each room?
Thanks for any help:thumbsup:
basically yes....make sure you are sqaure on and staff out the markings...the hallway is the focal point so mark it out first to largest cuts and see how it looks in other rooms.....Gaz
Did conservatory leading into kitchen then utility room not long ago. 48 square metres in total. Got central starting point in conservatory then dry laid one row into kitchen and utility. Adjusted accordingly until everything looked right then started fixing.
Did the whole ground floor of a house once 90m2 prick fashion we did each room individually with a mosiac threshold witch fited exactly in the door threshold...... center each room individully looked a lot smarter with big cuts in every room.... whitch you would not get if you tried to do it all in one.....:yes:
Nice one jonesy,....gr8 way if getting the rooms all to mark well, did a similar thing years back but fitted hardwood thresholds that matched skirtings, doors and stairway.......Gaz
we did it with a tumble marble mosaic looked well smart when it was sealed.....one of the rooms had a big tumble marble mosaic circle in the middle off the room whitch match the thresholds.......... you have to be make sore your mosic is the same thickness has your tile mind....... if its thiner its a bugger to build up
Bloody right there, had a mosaic to fit in centre of conny once, had to tile the floor and leave a gap for it, then screed it up in layers until the right thickness...bloody nightmare....looked good when done mind....Gaz
Exactly what I do mate, dry lay a row leading ito each room and cuts can be worked out from there.
Did this about 2 months ago the fella only paid £60 for it of e-bay how goods that:yes:
infidel,
The Legend; Phil Hobson RIP,
infidel,
