terracotta finish
Me neither. It is a non flammable liquid though can give off a heavy acrid smoke Broken Link Removed
Insurance job if I ever heard one
Insurance job if I ever heard one 
Read section 10 of the above article.
I've witnessed this happen, it completely burnt out a van as a result. On the particular product in question, there was no warning label so the case was pursued through the manufacturer and settled via their public liability insurance.
Back in the day, when this was a more popular product, I laid 1000's of sq/m of this stuff.
Saltillo Mexican terracotta. (Named after the town which is famous for it's production).
It is made in molds and left out in the sun to dry simply plied up on top of each other. The yellow tiles are actually the ones sat on the top of each pile and far more exposed to the sun and bleached basically.
If you treat with boiled linseed oil, don't just keep slapping it on, it will simply keep soaking it up, as you found out. Two coats with a paint roller are enough, then allowed to "cure" overnight. The oil congeals in the tile overnight and acts as an impregnating sealer.
So you've laid it, oiled it again, and it's still sucking up oil. That's normal, leave it overnight again before you grout. It doesn't matter if there is oil residue as the coarse grout you need to use with this width joint will clean off the top of the tile surface. We never used to dilute the oil, always used neat.
Give it a good clean, leave it overnight.
If the customer then wanted a finish, we would avoid wax as it was very labour intensive and never lasted a great deal of time without looking rough. So we would use HG Golvpolish, just wipe it on and allow it cure, it would create a warm satin finish, like wiping vegetable oil over the surface and bringing out the colour. It had the advantage of being removable so once a year it could be stripped and re done.
HG decided after years of using this stuff it was no good for terracotta (never knew why though) so replaced it with a bespoke product. HG Shine Seal, which I'm pretty sure does exactly what Golvpolish did.
Oh, and never ever screw up a rag or towel coated in linseed oil, the self combust. My partner at the time burnt his van out having done this once, Fire brigade out, neighbours gawping the lot!
I agree . Looks like the good mexican saltillos. elon tiles were first to bring them in about thirty years ago.would agree with everything ats says . do not just keep adding coats of oil one after another without letting it cure overnight. they will just get darker and darker.
i always found these tiles rather problematical and may be biased because i was a fired earth man mainly , but elon used to bring in their own sealers from usa, where the tiles are very common and thier sealers although horrible to use and gave a very shiny surface seal did stop the tiles from staining and helped the big issue in that these tiles have salt deposits buried in them and quite often just under the surface.their bentons traditional and duraseal 500 system was heavy duty surface seal and protected the surface.
When i did a few jobs using boiled linseed oil and either wax or HG Golv on top, it was only a matter of time
and this could be 6 months or two years and then the surface would explode with large salt nodules showing underneath where top of tile popped off. bits about size of 50p in most places and all over the floor.
i suggest that you contact elon or corres who also used to specialize in these and see if they have a surface product that is compatible with linseed if that is what you have applied already.
oh yes i and i too set fire to my mums car with old sodden linseed oil rags. fired earth had a house burn down where chucked in bin under units in a house so beware!!
yes they could be saltillo hard to see not a great picture and yes have seen more than one fire with boiled linseed oil could tell some storys lol and corrilo you couldn't use oil didn't work just soaked through bentons was shiny that why i didn't use it
you remember the bentons as well pjc . before that they had duraseal 500 plus top coat cant remember name. even worse than bentons but it stop the tiles exploding!!!
beginning 80's it was quite weird in that there r were only two tile shops selling hand made terracotta and they were next door to each other in holland park. Elon and fired earth.
Blimey i remember those days well.
we were told to grout the tiles with bis sandstone grout but advised to have barely enough moisture in grout mix so that it just bound together in ball in your fist. fired earth were terrified of tiles staining as we were as this was new in uk.
were told to bang the grout in to joints with a squeegee that had thick rubber strip .I lost the use of my right hand for 9 months from repeptitive bashing of grout in to joints. couldnt grip anything.
lol! thanks for responses guys, PJ, that finish on those terra you said was the same but upside down.. Is that the patina you mentioned ? Looks great and exactly what the customer is after! ATS the HG produce..does this give a similar look?
In regards to the fire risk!! Ive been paranoid! lol! Got to the point the other night when I woke up and threw work clothes out of bedroom window in case they burst into flames! lol! true story. Must have been dreaming about it!
What do you guys do regarding your work clobber, I got it on shirts, shorts dust sheet etc, Im assuming its the same principal???
Been up on job today cleaning them up ready for grouting tomorrow. The sealing time, I think I was just making sure to be honest, coated full tile twice using wide soft brush, it was awkward doing it due to bad weather and limited space, and again, I was being cautious with them, with having limited experience, not to mark them while handling..
Enjoyed working with them, makes a change from trav and porc which is all I seem to be doing lately
Go grab a bottle of the HG stuff and try it on some off cuts, I think it will give you the finish your customer is looking for.
Any cloths I had left over at the end of the day I used to throw in a bucket of water and leave them to soak there overnight.
If they manage to self combust in a bucket of water then I'm out of any further ideas!
It's really only an issue of not screwing the stuff up into ball - leave it flat and nothing will happen.
terracotta finish
TMTservices,
TMTservices,
TMTservices,
TMTservices,
