Dewalt D24000 mitre
Hi all,
Ive just purchased a D24000 from my local merchant and really look forward to getting stuck in with it, however after setting it up I have attempted a few mitre cuts and I have noticed that the tile whether porcelain or ceramic is chipping along the cut.:mad2:
Has anyone any idea of how to rectify this? I am unsure if its a calibration issue or poor technique.
Cheers for any input:thumbsup:
1st of all make sure the machine is correctly set up and the tray rolls smoothly on the tracks. If you can lift the rolling tray off the tracks without moving it to its most rear position then its not installed correct.
Then take a square and lay it on the rolling bed tight against the measuring fence/guide. Use this to establish the wheel is installed correct.
Make sure you have a good flow of water while cutting.
Let the rolling tray glide through the cut and do not try and apply too much pressure.
Different tiles may give different quality cuts. If you are still not satisfied then you can get better diamond wheels although I was impressed with the standard wheel supplied....please note there are 2 different Dewalt wheels available and one is better than the other ( so they say).
Try scoring it first, or cutting straight with the dewalt before cutting the mitre. Some tiles are more prone to chipping. Sometimes a new blade can cause it too
Indeed , its always worth running a new wheel through a tile a few times to bed it in. They always seem to cut better this way.
Try this...
when cutting, make 1 - 2mm first pass, do this a few times then commit to full cut.
Try this...
As Charlie says, use the plunge and slide, rather than just the slide on its own with the blade fixed in the down position. That's how I do it and get good results 9 times out of 10.
I had the same problem today fitting some porca wood planks which I was cutting for skirts,but to be fair,they were chipping a bit just with the rubi,but it looked fine,looked like part of the wood effect 😉
A decent blade really helps too. Someone on here is selling a DNA blade that is suitable for the dewalt. I couldn't do without mine it cuts almost anything chip free.
Dewalt D24000 mitre
DavieA,
ishi69,
DavieA,
ishi69,
