Advice please on primer and adhesive for anhydrite screed
I am seeking help on recommended products for use on dried and sanded anhydrite screed with low temperature UFH.
I need to stick 18mm plywood to the screed for some floors and porcelain tiles for some others.
I know I need to have flexible adhesive and a compatible primer and adhesive, but would be grateful for some product recommendations and tips e.g. best trowel for 600 x 600 mm tiles.
Thank you in advance.
Frances
The op has probably been watching "The 100k house" where the architect specified plywood as a cheap finish for the floor.
Haha, I was thinking that, or OSB & sand it & varnish it.. [emoji27][emoji27]
Tilemaster do a good primer 3:1 water to primer and then tile with their anhyfix adhesive or ditra first and then tile with cement based adhesive
Mike
I would go gypsum based for the tiles and sika for the wood. Don't stick the wood down with tile addy.
frances.inglis,
Ajax123,
frances.inglis,
Ajax123,
