The Use Of The Multi Tool
Afternoon all.
I've been reading who uses a multi cutter on doors and architraves etc to get a tile to slide under, but do these cutters work on cutting tiles and has anyone any experience of this?
When I was having my drama the other week, trying to envelope a tile that was too big for my wet cutter (see how do I cut this? thread) the general consensus was to cut it with a grinder. Did it, neatish job, customer happy.
But what if its thrashing it down with rain outside, nowhere to get the grinder out (too much dust for inside). Never heard of a tiler being rained off! Can the multi tool cut tiles or is a combination of grinder and wet cutter the only solution?
Your thoughts please.....
Afternoon all.
Buy a pop up shelter.......... then you can cut outdoor or use 110v stuff and you can still cut outdoor or buy a decent battery grinder and you can still work outdoor
I'm not sure you could get a multi-tool to start up gently enough to get it in place nicely (does that make sense) also, because it oscillates back and forth, I think you'd be looking at some chippage at each end of the cut, whereas a grinder / wet wheel presents a continuous or at least a cutting blade that only spins in one direction....
Bosch do a diamond half disc specifically aimed at cutting tiles,
I've not tried it or bought one, they're £49.99! 😱
The grinder seems to be the best option. £50 a blade and no-one knows if it'll work! Not going to risk trying it. Still want a multi tool though
Does anyone use multi tool for removing old grout or broken tiles?
For grout yes, tiles .......not that I can ever remember.
Just old reliable SDS and hammer and bolster/chisel/screwdriver/wood chisel/ anything pointy/ bigger hammer/ or client! 😀
Just a slight different direction to @ANDY F post, which are best, battery or cabled versions?
Both have their merits, battery can be convenient and quick.. Stops u having to find power but can be restrictive cos they tend to be bulkier.
Cabled have more grunt, are generally smaller, but finding power can be a pain and getting tangled in the cable when you're in a tight space is grounds for smashing it against a wall!😀
Hope this helps!!!😛😛
ANDY F,
highlandtiler,
ANDY F,
highlandtiler,
