Very Large Format..concrete Panels..on Walls
MW Smith Ceramics
Hi everyone,
In need of some professional opinions on this one, I'm pricing up fixing some 1200 x 800 decorative concrete panels inside a living room.....13 metres in total/2 walls......the problem is the panels weigh in at 30kg per metre with adhesive and the walls are plastered!.....British standards only allow 20kg per metre so what would you guys do here?
I was looking at either electric sander on the plaster back to the plasterboard to allow 32kg per metre but what a game that will be and a right mess in someone's living room........or do I mechanically fix new plasterboard on top to the joists but client doesn't want wall coming out any further as this decorative concrete is 15mm thick as it is !......or do we take the plasterboard down and mechanically reboard new plasterboard onto stud work ????
Oh aswell as the panels being stuck with a 2 part adhesive the joints are created with fixing clips, wall plugs and screws to also horizontal joints to help strengthen/ hold in place the panels......the manufacturers have actually told me it would be fine to go onto the plaster with Mapei primer G then Mapei keraflex which is an s1 but I'm sure you need s 2 part s2 adhesive with this size tile???
Has anybody had any experience fixing this stuff??
What would you guys do here?
Any advice would be appreciated
Mark
I'm no expert in these large tiles but I can't see why a regular single part flex adhesive won't suffice unless it's to do with the material the tile is made of, which I can't see being a problem if it's concrete!
As for the wall, sounds like you have 2 options, take the plaster boards off and put something more suitable on, or fix to the plaster it's self.
Well after speaking with Mapei technical today they are insisting that an S2 addy should be used to accommodate the size and weight of theses panels and definately not tile onto the plaster at a meterage weight of 30kg - ( british standards states 20kg onto plaster )......
So I investigated further and spoke to british gypsum this afternoon and they told me there is no way of removing the plaster and getting back to the plasterboard without damaging it........so I think the avenue I'm thinking of taking here is to remove the existing 9.5mm plasterboard and skimmed walls completely, get back to the studwork and mechanically fix a 12.5mm plasterboard then install the concrete panels unless anybody has another solution??.........anyone???......just a lot of work but you don't want these bad boys coming off the walls when the family is watching telly!......YIKES!!!☺️
It there's stud work why not over board with 12.5mm plasterboard....
Hi mate,
Yes that is another option, I did put both options across to the client but he just wants me to fix onto the plaster as the manufacturer of the panels say they do it all the time and haven't had any comebacks.......maybe it's one to walk away from and let someone else take the risk of fixing 30kg per metre onto plaster......its reputation that matters and I'm not gonna risk it..........
Hi mate,
Client doesn't want the walls coming out any further as these panels are 15mm plus adhesive
I wouldn't entertain fixing those on skim. The client shouldn't either. Imagine one of those coming off for the sake of a few quid!
Yeah for sure it's just wrong isn't it so its one or the other, mechanically board over to existing stud work with 12.5mm plasterboard or remove existing skimmed board and fix new 12.5mm board to the studwork.........ill put these options across and if he still wants to go onto the plaster then it will have to be another fixer......
Thanks for replies anyway chaps......much appreciated........where were you on this one 3fall??..........I was hoping you would have posted on this and put the debate to bed
MW Smith Ceramics,
MW Smith Ceramics,
MW Smith Ceramics,
MW Smith Ceramics,
