Topps Tile 750w Cutter
Derbylad
Hi All,
I'm looking for a tile cutter for DIY use.
I've spotted this one and wondered if it is worth the extra money?
Electric Cutter 750w | Topps Tiles
compared to
Portable Wet Saw 750W | Powered Tile Cutters | Electric Tile Cutters
Or can you suggest another cutter?
I will be using it for wall tiles.
I did think about a manual cutter but from research I read that they can't cut off narrow strips of say 5 to 10mm
My old cutter was a Plasplugs I bought about 10years ago from B&Q. It was fantastic for about £70, cut everything. Sadly it passed on after much use.
Thank you for reading
As above and bought a porcelain blade from Topps which is excellent....bore size is an odd size.
Thank you for the replies.
I shall go for the Vitrex and then look for another blade if I have problems cutting.
Derbylad,
Derbylad,
Derbylad,
Derbylad,
