That user name returns no results Goz.It was only a refurbed one from their eBay site user name Gccss2005 can't remember the actual company probably have more, I'm well chuffed with it, does so much makes my life easy.
Items in GCCSS2005 VIPER CLEANING EQUIPMENT shop on eBay. - http://stores.ebay.co.uk/gccss2005vipercleaningequipment/That user name returns no results Goz.
I, 2 adhesive bags, above my supertitina. 😉You wanna try to treble that 25kg
Yep, thanks.
When I bought a couple of years back they had a lot of refurb stuff that doesn't appear on there at the mo.Yep, thanks.
Praps I needed to add the viper cleaning bit when I searched the app.
Anyway, thank you.
Ok kool. Been half chasing one for a while, used to own one years ago, not even sure what happened to it hahaWhen I bought a couple of years back they had a lot of refurb stuff that doesn't appear on there at the mo.
Sanding Tools & Abrasive Equipment | AbTec - http://www.abtec4abrasives.com/Yeah black pads are the coarsest pads, white are the finest then they increase through to black, the darker the colour of pad, the coarser they are.
My drive pad was damaged when I first bought my machine, and lent it to a builder "friend" before i had a chance to use it. He returned it after using the incorrect grinding disc for the drive, and wore the plastic base of the drive flat, so wouldnt grip normal pads.
I told him to replace the drive plate, but instead of paying 120 noted for a new one, he bodged a wire bristle pad on the bottom. It works, but not as meant to be.
I was lead to believe from looking tonight, sanding pads require a different drive plate?
Can you post the site you use please?
Thanks for the link, how do you attach the double sided pads? Nail them on?
Double sided? I got the 430mm ones with like a felt/Velcro backing, my drive board has Velcro pads on the bottom?Thanks for the link, how do you attach the double sided pads? Nail them on?
