Screwing hardi backer
Kyle Knowles
Now usually I always use my impact driver to drive screws in hardi but I had the idea of getting some collated wood screws for my hilti collated driver and i tell'ya what I'm never goin back I screwdriver down 10 hardi board in about 3 mins flat and u can set the depth so the counter sink perfect I'd recommend if u fit a lot of hardI invest in a hilti SD 5000 and SMD 57 collated attachment u won't regret it
Do you not find that the dry walls screw heads shear off?? Turbo golds for me.
Left this for a while before replying as thinking about it I had only used the drywalls on ply and on insulation boards but knew I had a bathroom floor to do using hardibacker 6mm - did it today using the drywalls and every screw went in fine with no sheared heads.
Drywall screws to brittle wouldn't recommend using them to fix anything to a floor. If you screw one straight threw a stick then tap the end with a hammer you'll see how easy they snap.
I'm going to get my makita collated screw gun out again had lots of trouble with it jamming but was told to lube it . Hope it does the trick . Has any body had problems with makita collated screwdriver.
Kyle Knowles,
Kyle Knowles,
Kyle Knowles,
Kyle Knowles,
