dot and dab
No need for anyone to be confrontational and hissy. Everyone here knows dot'n'dab can fail and we've seen the pictures to prove it. Its going to take a miracle for you to convince others it's ok. You just have to show everyone your method is different to the dot'n'dab that we all know and hate and that it works.
British Standards is a code of practice. They "recommend" spreading the adhesive so thats what everyone is going to do. If anything ever goes to court, that is the definitive black and white that they'll lean on. And if its not been done, prepare to duck the book when its thrown at you. Spreading is also part of the foundations for many of the adhesive manufacturers guarantees. Ignore that and you ain't got a claim if anything goes ****.
Personally I can still see it being quicker with a trowel. If it needs bedding out, spread the wall/floor and the tiles to double the bed depth. Or even "hover" the trowel away from the wall/floor to increase depth. Or better still, correct the wall/floor before starting.
But saying all that, you'll have a slim chance of convincing more people (even though they won't adopt the method) if you take pictures to back it up. One with the dabs and how you set them out, one with the tile fixed flat ideally showing the bed depth from the side, and another after you have just lifted it to prove the coverage you have obtained.
Then maybe we can move on and argue about something else. like which is better, Sigma or Rubi.............
I'll get me coat!
I'm starting a job on Monday so when I start the tiling, I'll take some photos for you all.
There's no way tiles should be coming off a wall, ever...
And I'll never correct a wall that's 5/10mm out other than bedding the tiles out to suit, it's just extra work that would be unnecessary...unless there were mosaics or small tiles being laid 🙂
I won't be trying it....thanks..
Probably tile the whole bathroom by the time you've 'blobbed' a couple of tiles !!
Well all I can say is that you asked me how I get my adhesive to key to a substrate, I've told you what I do then I've advised you to go see for yourself. I didn't ask you to tile a whole bathroom using this method, I simply advised you that you should TEST 1 tile out for yourself...
If your asking questions on how adhesive keys to a substrate, then you're clearly not qualified to give out advice on it
Quicker is not necessarily better...
I guess you mean on the condition that it won't exceed the maximum bed depth. You mentioned Mapei Pro Flex in a previous post. Is that your standard weapon of choice for most projects?
Mapei Pro Fex is 15mm max. Yeah, that's all I use these days, its good strong stuff. Bal is good gear also, just a little too expensive for what it is, I find.
Wow....you really are full of yourself I'm sure your going to make loads of friends on here...🙂
Mapei Pro Fex is 15mm max. Yeah, that's all I use these days, its good strong stuff. Bal is just too expensive for what it is, I find.
I'm not here to make friends. I'm here to talk about using a different method to which has, for the most part, been met with hostility, ignorance and sarcasm...
OK, my 2 penneth; we should be aiming for 100% coverage. In reality we probably get 70-90% with notch trowel and back buttering.
You can achieve the same with multiple dabs of adhesive.
Disadvantage of dabs for me is i think it would take longer. It is a temptation to 'make do' with less coverage, and I'd only do it if i skimmed a layer of adhesive into the wall anyway.
Dabbing has it's place, i certainly do it when needed, but i would rather spend the additional time prepping my substrates.
Ste450 has been clear that he's not spot fixing in the sense most of us immediately think.
I understand where you are coming from with your way of tiling and I also believe you will have very few, if any, failures.
But if you read back through most of your posts in this thread. You will ( I hope) see that they are vey confrontational. This gets others defensive from the off.
Do you skim any adhesive on the back of the tile or the wall or do you put blobs all over the back of the tile then stick it on the wall ?
My first post wasn't confrontational at all, I put my point across well. A lot of the replies of mine to forum users afterwards, I'd agree were confrontational. But, when your getting told that you live in "cuckoo land," and being told things that would totally contradict your own findings and experiences, would you not feel compelled to confront these types of comments? Maybe people shouldn't be so arrogant in the first place. I agree that the way I write, sometimes can come across as quite direct, but that's not necessarily a bad thing. I have no problem apologising if I'm in the wrong either.
dot and dab
diamondtiles,
Qwerty,
diamondtiles,
Qwerty,
