Once and for all (hopefully!) CEMENT Boards Explained
It feels like there is a constant asking about the suitability of cement board in wet areas.
"Will they be ok in my wet room?" "Should I tank them?" etc etc etc
Can I attempt to clear up the confusion - much of which comes from the manufacturers and the builder's merchants who sell the stuff?
First of all: WATERPROOF vs WATER-RESISTANT
I honestly want to bang my head against a wall when this comes up.
1) Waterproof means water cannot get past the board.
2) Water-resistant means ONLY that water will not damage the board's integrity.
BUT - water can still soak through the board to the background.
Cement / Silica board - I class as Hardibacker / AquaPanel / NoMorePly
These are NOT WATERPROOF. They are sold as suitable for showers / wet areas etc and in my opinion they should not be sold as such. They are only "suitable" in as much as they won't get damaged by water - but unfortunately in my experience they will allow water to damage everything else - your tiling, your timbers and your rooms next to and below the one they're in!
The negatives of these boards:
- Heavy
- Difficult to cut
- Slow to install
- Contain silica dust (v harmful)
- NOT WATERPROOF - require tanking to make waterproof.
(note that tanking will reduce inherent weight-bearing though)
The positives:
- very strong and can take great amounts of weight
OK - Waterproof Boards now:
I class as Schluter's Kerdi board / Wedi board / Marmox board / Delta Board - there are others claiming the same properties but I can't vouch for them.
These boards are WATERPROOF. Water will not pass through the board, unless you leave open gaps or puncture with fasteners.
If you seal the gaps and fastener holes with these - water cannot get through and cause unseen damage.
- require specific washers and fasteners.
The positives:
- Lightweight
- Very easy to cut
- No harmful dust (zero with Kerdi board)
- Very fast to install
- TOTALLY WATERPROOF when installed correctly
- Very strong and can take great amounts of weight
Hopefully for some not so familiar with these board-types this will help to show that using a cement board in a wet area is a total waste of your time and money.
Not only are you working with a difficult board, but you then need to tank them too.
If you use a waterproof board, not only are they far easier to work with, but you don't need to tank them either.
I install loads of wet rooms (and replace loads too) and I've learnt over the years that you MUST keep learning.
Keep asking WHY as well as HOW. Go on the manufacturer's training days.
Any questions???
Any questions???
Whose going to win the snooker masters, will Ronnie retain his title?
........so many questions! 😀😛
Excellent post Imp, very informative and helpful.
In my humble opinion the best system out there from my experience is Kerdi, for me it's second to none, Schluter have it nailed so to speak!
Just a point to note though, Ardex tell me that their WPC's weight bearing limit is the same as the substrates, what ever that may be? 🙂
Totally agree Lee. Kerdi is the best so far. I use it wherever i can. Still a pain to actually purchase still though!
I know ardex claim no effect on weight bearing but I'm not totally convinced. You seen the demo rig hardibacker have used where they hang a concrete slab off the board? I'd like to see the same board with ardex wpc on it!
Still, ardex wpc is my tanking kit of choice for plasterboard anyway.
- Heavy
- Difficult to cut
- Slow to install
The positives:
The positives:
- Lightweight
- Very easy to cut
Any questions???
Hi Impish, Quality post mate, just starting out and soaking any info from experienced guys like a sponge, Love this forum!! Regards
Steve
Now this is just typically weird. I'm halfway through tiling a large floor, today the homeowner asked me to look at two bathrooms currently being prepped by their builder. Guess what they were literally just about to board the walls with?
Aqua panel.
Now changed to Wedi board.
I think the builder wanted to hit me!
So just to clarify, board out with hardibacker, tank with gloss paint and prime with pva, is the best way forward. May I recomend on top of that to always use tubbed adhesive with the dot and dab method, ditch the tile spacers to save money and time, which also means you won't need any grout. And Silicon is so over rated, so if you just make sure the tiles are butted to the bath/shower tray or each other tile as tight as possible, you won't need Silicon
On a serious note...
Excellent post sir.
One Day,
RichBD,
One Day,
RichBD,
