Underfloor heating/issue with builder
If the instructions said it, and you did it then you shouldn't have anything to worry about. If it goes to court, all you have to do is take a copy of the instructions in and show them.
Whats the make of the heating?
He can't take legal action as you he gave you no option to repair it.
Because he fixed it without giving you the chance to put it right, this is classed as acceptance.
Honestly, you're safe no matter what he tries to do now.
For the record; I have installed countless brands of ufh and I don't recall any which don't stress the need to completely cover the tail ends in adhesive or slc.
I normally tape the crimped TIP down but make sure the actual tail is covered. I've had zero problems in 11yrs.
We'd never recommend to cover the joint in a masking tape or any tape as it can cause excessive heat in the joint. It could be that the joint was loose which has created heat and caused the cable to burn out as it isn't a secure connection. We always recommend to put our cold tails into a conduit and bury the conduit in a 15mm channel in the floor, before being self levelled.
Taken from their installation instructions:
Once in position, remove the backing from the adhesive
tape attached to the underside of your mat/s and secure
to your base (fig 5). Any loose cable or mesh can be
secured by using a hot glue gun or masking tape.
I cut and paste what you posted into Google. If it's the manufacturer i think it is, page 3 says make sure everything is covered in adhesive, or screed.
I think you misunderstood 'secured' with the need to cover...
thickbed,
SJPurdy,
thickbed,
SJPurdy,
