Tile cutting problem
Are you using the breaker or jackie channing them?
On stubborn tiles I find that slapping them with your hand works better.
Try adjusting your sigma rail depth so it's scribbing with firm pressure but not causing the tile to ping and snap prematurely. Personally would only scribe once.
Bit time consuming but id get a new blade on your wet cutter ,my nd200 just packed up but had it ten year ,usedthe best blades cuts anything with ease
I've tried the gentle approach, scribe 50 times approach, jump up and down on it approach.........come to the conclusion there crap tiles..
Try this, when you've scored them at both ends of the tile, score a 45degree off the cut line also then break or snip that piece off, then when you go to snap off at your intended breaking line the tile will break where you want it to because the main body of the tile is on the stronger side of the score line. It works for me every time.
Andy Allen,
Houston,
Andy Allen,
Houston,
