Discuss Best tile levelling system in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com.
what
What is the best system to use?
Vitrex lash tile or suretile?
a>
Three systems I've used extensively
PLM perfect level master straps are good strong very few snap when installing the wedges they have a new longer strap for 20mm stone straps come in 1mm 2mm and 3mm
Mustang similar system to the PLM as in its a wedge style system again very good can just about cope with 20mm stone
MLT is the engineered system all parts are reusable you only loose the clip that goes under the tile so the straps can be used many times, this is a Rachet down system takes a bit of practice to get used to using and set up is time consuming so not really for the meter munchers.
it comes as a kit where you clip the straps to the feet which sits under the tile fit the next tile then rachet down the cap and lock off with the gun. make sure the straps are properly bedded into the clip though as you can pull them through if you apply to much pressure.
the cap also comes with a little stainless steel plate that you can add to the top of the cap this gives a more positive rachet action and worth the extra expense, they also do a rubber boot that fits to the bottom of the cap for delicate materials although i haven't seen the need as yet to use so would say an optional extra but points for trying to cover every angle! MLT is very popular in the USA with strong sales and a very good delivery system there here in UK no one is a direct seller and you have to order from Italy but very good is sent within 3 days so not bad..
MLT is the most expensive to first buy but should pay for itself over time as its reusable
we install stone mostly and i would say that on highly polished or lacquered stone neither the PLM or The Mustang are suitable as they leave scratches which is not good a racket down system is the best one to use for polished stone
Reply to Best tile levelling system in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com
  • Article
Stoke-on-Trent College provide Tiling courses for school leavers and mature students with both full and part time tiling courses available to enrol on to. The cost of these courses can vary and it...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
