Best tile levelling system
Has any body used bright idea copy of Raimondi clips who has also used rls clips or similar . I use bright idea ones all the time but wondered how they compare
I've only used perfect level master and they've been great. Never had an issue of the clip breaking from pushing wedge in. Long as joints are fairly clean they snap where you want.. expensive compared to others but like I said. 5* rating from me.
In my experience the best system I've used has been the Genisis. I haven't tried any Rubi or MLT systems. Vs the RLS the Genisis system for me is better because it doesn't move the work pieces laterally at all during the clamping process and also therefore can't mark the surface like RLS could on some stone. It is also more versatile in its range of depth. It costs approxamitely 50% more which is the only downside apart from the pliers wearing out too quickly.
I used the twist on self levelling system as shown on page 1 of this thread. I found they worked really well.
There two types; one with a cross which also acts as a 2mm spacer, and one with a straight line, also acting as a 2mm spacer. The cross is for using where 4 tiles meet, the line is for other joints.
Due to my layout, I used the line spacers, but wanted a 4mm gap so had to also use traditional spacers. I used 3 clips per joint!!
When tightening them, both tiles will move slightly, giving an almost perfect joint. To remove them, I gave the yellow know a swift whack in line with the joint and then the yellow bit is reuseable once you remove the spree from it. I'd highly recommend these.
Best Tile Suppliers | Tile Supplier Discount Codes
what,
Ralyban,
what,
Ralyban,
