Kerakoll adhesives and grouts
Tried a few little tests last week to see if there is any problem with shrinkage regarding Kerakoll H40 no limits white, even with build up of 20mm under 600x300x12mm porcelain (test only) with a 2mm joint down the 600mm length left and checked all week. Joint stayed exactly 2mm no more no less. Height kept exact. Mixed adhesive to exact spec and never added more water again. Sub base was 1 onto concrete, 1 onto cement backer board and 1 onto Wedi board.
Got to say really is a good all round adhesive, lovely to work with and will be my preferred adhesive now!
yes, it should be the same. something has changed, they can write c2 te s1.
H40 no limits they can not write it, just written gel technology.
In italy, for now there is no biogel, I think it is only for some countries, in germany there is biogel.
Infatti, perché sei vecchio.....ti ho chiesto.
Hai detto, preferisco quella vecchia, quale vecchia?
Blunt Tool,
Fraser Tiling,
Blunt Tool,
Fraser Tiling,
