Brick Bond (Metro) advice
Actually, thinking about it, the window sill will be 8mm/10mm instead of 9mm/9mm
I'll chop off the bevel where the trim meets bevel, and then have a full tile touching the window. 8/10 would then reflect all the way on the inside of the the window frame. Does that make sense?
Here's one I did earlier, someone else had tiled, but the customer got me in to remove quadrant trim and tiled sill and fit new 'L' trim and window board.
DIY Tiling Forum
Zub,
Dan,
Zub,
Dan,
