What SLC to use over UFL
One I did on Friday, I needed to bring it up 10mm so I stuck 10mm squares of board in a few places and brought it up to that. The squares often look proud as they can get a raised bit of leveller sat on top of them
I prefer to use screws to set heights as they can be set at different heights if substrate is uneven
If a floor is already flat and level and I’m fitting ufh I will just pour and not worry about setting height markers.
I do it by eye and hope for the best. Usually works out though, I've been doing it like that for years.
Tiling on Underfloor Heating
Tags Tags
slc what
Kevin09,
Lou,
Kevin09,
Lou,
