Setting out a floor..........
Setting my floor out, is it worth dry laying g and doing all my cuts then doing the adhesive or do cuts for half the room and then adhesive. It's a 4m squared porch. What do u prefer
What type of adhesive are you going to use?
I often will dry fit small floors of that size when I’m using a 2pf, just be sure to mark the floor so the tiles go back in the exact same position.
Bag adhesive, standard, I'm told it has 2hrs on the buckets got time, but cuts are the thing taking the time, need a better way of making templates
Awkward angles no right angles... Is there a better way than templates with paper
Either dry lay surrounding tiles and use another tile against surfaces to mark out cuts required or use a steel rule
Stevev,
Matthew77,
Stevev,
Matthew77,
