Discuss Setting out a floor.......... in the Canada Tile Advice area at TilersForums.com.
L
LM
Setting my floor out, is it worth dry laying g and doing all my cuts then doing the adhesive or do cuts for half the room and then adhesive. It's a 4m squared porch. What do u prefer
What type of adhesive are you going to use?
I often will dry fit small floors of that size when I’m using a 2pf, just be sure to mark the floor so the tiles go back in the exact same position.
Awkward angles no right angles... Is there a better way than templates with paper
Simplest way for you to make a template is to cut thick cardboard in to inch strips, (tear up an old box or something) once you have thin strips, trace the outline of the space with your cardboard and either tape or use a glue gun to stick strips together.
You will then end up with the exact shape that the tile needs to be.
Something like this. As they’re small tiles, cardboard will be stiff enough, or anything you have to hand, just not paper.
Wishiwasatoptiler
1,118
Northeast
I only dry lay and cut what area my bucket mix will lay, I lift each row of tiles in the same sequence with the tile I place on on top the one I will lay First off on that row, if that makes sense, you can get a number of angle finders which save making templates but for normal externals and internals just do as Plan tec says.
https://images-na.ssl-images-amazon.com/images/I/61D-RlTtCuL._SX355_.jpg
have a look at this, its canny.
Reply to Setting out a floor.......... in the Canada Tile Advice area at TilersForums.com
Hi, First floor tiled, seems setting out way trickier than a bathroom! Alcohol down yesterday...
I'm planning on tiling my porch, and the tiles and adhesive will take up around 13mm of height...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Blandford forum
Business Name
Steve Vaughan Tiling Services
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 2 1.2%
    Votes: 5 3.0%
