thank you all for the comments, but this time it was tough.
I had to cut almost all the tiles with freehand grinder.
with raizor, it was impossible to break the tile well
with the power raizor, I had to make two passes, first pass 3 mm
and second pass another 3 mm, otherwise it broke badly.
problems I had not had with 320x160 laminam.
we will see the next 240x120 scheduled for the month of August.
Is it possible to score it first (with the Raizor) before you used the Power Raizor to see if that stopped them breaking?
Is it possible to score it first (withe Raizor) before you used the Power Raizor to see if that stopped them breaking?
but I think I have found a solution.
a blade installed on the grinder at 11000rpm,
it was too fast and tried to break. the same blade installed
on the 9000rpm battery grinder it was faster and without breakage.
I will install a variable speed grinder on the power raizor
and with a passage I should solve the problem.
a € 13 knife saved my work, the other more expensive blades
they created problems for me.
I will also try as you say, pass with raizor and after power raizor.
unfortunately in this work, I could not do many tests.
as usual haste always wins the good work.
inhabited house, no place to install all the tools.
Tilers Community
20K
Italy,
Robbert,
Italy,
Robbert,
