Help needed with mosaic splashback
Use a white adhesive. Use a montolit cutter with a mosaic mat to snap them. If you need to cut with a grinder use a variable speed one with a blade suitable for glass. Montolit do one. As its a small area the metal ones can be cut seperately if necessary . Also instead of using tile trim why not use the rectangles to create a frame and cut into that? looks much nicer. I did the same with these Fired Earth mosaics.
Thanks very much for your help, what colour of grout do you think would look best on the mosaics I’ve picked?
That goes really well with the kitchen worktop. Like it a lot. I’m intrigued, what did you do round the external corner?
DIY Tiling Forum
GlasgowMan,
Dan,
GlasgowMan,
Dan,
