My 1st Job Sealing around shower door frame.
The Enforcer
I have refitted my ensuite and I have made it to the last step only to run into trouble I cant seem to fix.
I have a tiled shower floor with wet room tray underneath, all tanked etc and tiled the walls. Sliding shower door frame fitted. Siliconed up where the metal meets the tile but I keep getting a tiny amount of water though the frame.
I have removed the Silicon, cleaned it up, refitted but still the same problem - only slightly better this time. It is somewhat "submerged" as it gains about 1cm of water as the 4bar pump through the Grohe RainShower really dumps it out.
Should I have primed the shower door frame or anything like that ?
Both sides actually.
But since removing, just the inside.
Im sure thats what the destructions said to do.
Which shower screen brand is it?
I’ve never installed a screen that suggested you seal the inside. Not the bottom horizontal profile anyway.
There are quite precise instructions for sealing shower screens depending on the type. Perhaps if you posted a photo?
What Silicon? Mapei or Dow Corning would be my choice. Use a Fugi tool to smooth it out. Ensure its all thoroughly de-greased before
My guess is it is coming through where the horizontal and vertical parts of the frame meet or as you have a build up of water within the enclosure it’s making its way between the wall channel and frame.
This is what I think. I think it was making its way through the wall channel and it was coming out where the lower horizontal met the upright.
Photos to follow.
Here are the photos of the room (my first real effort at tiling) and the shower enclosure.
Its currently not sealed on the outside. But it is on the inside. After studying the destructions - it doesnt seem that it should be sealed on the inside. RTFM!
But even so - when it was sealed on both sides - the water still got in and came through where the lower bar meets the side bars. IMG_20190318_194448.jpg IMG_20190318_194424.jpg IMG_20190318_194356.jpg IMG_20190318_194345.jpg
My 1st Job
Tanking and Wetrooms
The Enforcer,
White Room,
The Enforcer,
White Room,
