Help with external corner please
Take off the offending tiles get 2 more tiles cut them a bit longer and chamfer of the back at 45 degrees then it will match the bottom tile .
Whilst your at it, might want to change the bonding , as it’s brick bond, half tile should follow on the end, of the full tile, as it would appear on a brick corner.
Thanks for yours and everyone elses advice. This is a holiday let so I'm going to use some trim on the external corner and cover the dodgy area with a kettle! Unfortunately I don't have the time to get another tiler in. Lesson learned on this one.
I find it quite frustrating what owners feel is acceptable in a holiday let or rental property. I look after holiday lets here in Spain and I'm dropping one owner this year because of our differences over what is acceptable for clients who have paid hard earned money for their holiday. The same for my house in the UK. If I wouldn't live with it I don't see why a tenant should have to.
No offence intended, just sharing my opinion!
Yes I agree but the rest of the property is top notch. Hand made furniture, laura ashley wallpaper and curtains, top of the range mattresses etc. Its just a shame the tiling will let it down.
For the sake of a few hours work replacing a couple of tiles and mitering the corner, caulking along the top then paint down to the tiles, cleaning up the grout, then redoing that awful Silicon would make a world of difference and, IMHO, make the difference from another so so rental.
Thanks for your reply. The problem with mitreing the corner is that the bottom tiles are both bevelled so I think trim would be better. Do you mean scrape the grout off the top and put caulk on? What do you mean by paint down the tiles and in which area please? Why do you think the Silicon is awful?
The gap in the top tiles is bigger than the bottom. Mitering the corners would enable you to get an even grout line on the corner.
A smudge of caulking over the top of the grout at the top of the tiles will give you a smoother transition and nicer surface to paint. Fila Deterdek or similar will get the excess grout from the surface of the tiles. The Silicon should be a constant angle, yours is in and out, thick and thin.
DIY Tiling Forum
Nut,
WetSaw,
Nut,
WetSaw,
