Porcelain tiled kitchen floor - cracking after 2 days
Did he check the existing floor for movement before over boarding? Loose floorboards won't be strengthened with plywood. Which is now not widely accepted as a suitable substrate to receive tiles. He should have fixed a cement board to overlay the existing solidly-fixed flooring (presuming it's wooden). Then used an S1 or S2 flexible tile adhesive.
I hope so but its not sounding likely is it :-( Definitely no cement board was used. He came the other day to re-lay a couple and did use the correct adhesive after
i pointed out he had used a C1F previously (but i’m still having issues with others so will be calling him back). I’m a little worried he may have used the dot and dab technique - I took a pic when he went out for lunch - attached. I’m no expert by any means but there looks to be a big gap to me?
Its not all of it i’m having issues with at the moment (its one section - which I feel was rushed as it was the last bit and he was here until around 7pm as he had another job the next day. ).
Just all a bit of a disaster really. Wondering if I cut my loses and see if I can get someone to fix it (although I don’t have a clue where to start with that).
Pva is a no no , this so called trader isn’t a tiler and needs to be stopped. The whole job is a bodge.
:-( so frustrating as they have allegedly good reviews (god knows from where though!).
I think i’ve enough input from you all to just cut my losses and accept the whole thing needs re-doing by someone that actually knows what they are doing.
Hands down this has been my worst experience with using a tradesperson.
I’m afraid it happens, make sure you fully check the next tiler or even ask for a tiler in our find a tiler directory.
Thank you, will do. Thank you for all your help too - very much appreciated.
One saving grace is that tiles may well come up without too much difficulty and be able to be cleaned up and re-used. Sorry to see you have had this happen. It's shocking really that people can operate like this. Best of luck with getting it sorted out.
Don't believe all of these trade review sites. It is easy for people to falsify reviews. Try and get a recommendation from friends or family. That way you may be able to see the traders previous work.
Lisa123,
ElliotM,
Lisa123,
ElliotM,
