Discuss 1200 x 900 x 10 mm callibrated brazilian floor slate. in the Canada Tile Advice area at TilersForums.com.
kelvin
Hi all,
Pls can we have some advise for our up and coming project.
We are thinking of using the above mentioned slate and would like to know a few details from experienced trade personell.
The area to be tiled is approx 60 m2 will it require an expansion joint & if so what is the expansion joint made up of?
The slate will be bedded down onto a clay tile with UFH below whats the best product to use in this instance.
What is the minimum bed depth for a 10mm slate tile off this size so i can work out my finished floor height.
Also what are the laying cost at the moment for m2 for slate flooring im not planning to do this myself but will be supplying the materials any recommendations for tilers who lay large floor areas also welcome.
Thanks in advance.
Pebbs
I saw this interlocking brick system down at a job on Grovsenor Street, some time ago, and it looked very effective, I have one question, when you say the area is 60m2 are you talking about one large area or smaller areas making up this? This is important when considering the need for movement joints. Next question is this, what is the format size of the slate you are planning to install, as 10mm does seem thin, as Dave has already pointed out.
Pebbs
Reply to 1200 x 900 x 10 mm callibrated brazilian floor slate. in the Canada Tile Advice area at TilersForums.com
Hi guys, sorry for the clunky thread title... Just over a year ago we had a side...
Hi guys, i took some jobs as a contractor for some MC Donald's restaurants but i find it quite...
Moving into a new build property in the near future so planning the 33 odd sqm garage space...
Hello guys I’m looking for some advice I will be attempting to redecorate my living room which...
Hello all I’ve had a natural slate floor laid by a tiler employed through our builder. He seemed...
6K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
