Discuss 53 sq m travertine in the UK Tiling Forum area at TilersForums.com.
thegwads
Hi all
was hoping for a little advic eon a job coming up.
job is 53 metres. long hall going into kitchen, pantry and downstars loo. 40 metres here, looking like brick bond 600 x 300mm quite fiddy, a lot of doors and skirting is already on!!
13 sq metres up stairs spread over 3 batchrooms, so not too fussed about there, 2 on it should get those laid in a day.
downstairs though is a big job
can i run a few things by you
travertine, honed and filled i hope!
i will need white adhesive (flexi?) defo flexi upstairs, but concrete floor donstairs with underfloor heating installed. does this change things? do i need ditra matting or such like?
my plan is to seal, lay, seal again, grout, final seal - this sound good?
cheers
chris.tiling
Poole
Definitely natural stone white flexy addy (and flexi grout) as having UFH. I did a similar amount earlier in the year. Matting is recommended (though my customer declined) I didnt seal until after grouting, but I made sure I worked bloody clean and grouted small areas, changing water very regularly.
Skirting and door frames to cut round like my job too...I just went carefully and made templates to use when cutting tiles.
I got loads of help from on here...so watch the replies flood in! Good luck
trev
any idea on a price for the whole job?
what would you guys be roughly charging, labour only
Hi
I done about the same amount in May this year, upstairs & down with undertile heating everywhere. I would seal first and again at the end, as for price i charged £35.00 p/m labour only. Hope this helps.:thumbsup:
trev
Braver man than me, Trev. I would definitely have put down a decoupling mat personally. Lot of floor there to fix if it goes wrong. Hope it stays ok for you.:thumbsup:
Sorry, i should explain that was the total sqm area wall & floor. Kitchen floor 22sqm shower room floor 7sqm walls blah blah etc etc you get the picture. And your right grumpy, decuopling mat would be the way to go. What about an expansion joint? maybe every 10sqm or so? would that work?:thumbsup:
GazTech
Sorry, i should explain that was the total sqm area wall & floor. Kitchen floor 22sqm shower room floor 7sqm walls blah blah etc etc you get the picture. And your right grumpy, de-coupling mat would be the way to go. What about an expansion joint? maybe every 10sqm or so? would that work?:thumbsup:
Are expansion joints required with de-coupling membranes ??
Reply to 53 sq m travertine in the UK Tiling Forum area at TilersForums.com
Hi, just joined, hello everyone! I would like some advice if possible please. I am a...
8K
Mr Tiler
'Evening Gents, Recently joined the forum and have spent the last week trawling through loads...
hi, i been out for around a year now with a surgically broken leg and possibly wont get back...
oldgit
Hi All Just a quick few questions re Travertine advice please. I have had a call from a...
jasonj
Hi all Got a bit of a problem with a limestone floor and hoping you can advise and help. Here's...
2 3
14K
53 sq m travertine
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
