60 X 60 Porcelain
Hi, I would mark out as normal for each socket, take care to be accurate, cut with angle grinder £50 will get you a Dewalt another £35 for a diamond blade.
Mark out on the face of the tile and cut to your lines so the blade cuts through to the other side, turn the tile over and cut from the other side, knock the bit out.
It is time consuming, I would price it at about £40/m2 +tooling+materials, i am in the north of scotland so prices may be higher in other areas, if you have to cut the tiles to fit around the pelmit under the wall units you will have to be very accurate so charge more, don't under estimate how long it will take.
john
60 X 60 Porcelain
BIMP,
tileman,
BIMP,
tileman,
