70m2 bathroom!!
Sean fsy
on of the largest bathrooms ive tackled, after a fire at the farm it had to be totally refurbed, unfortunately some one lost their lives in the fire. when the customers bought their bathroom tiles etc they asked the place for the name of a tiler who the they recommend, also the company in charge of the full resto project, and they also asked the joiner who done kitchen etc aswell. all 3 companies are based about 30 miles apart. Yes they all gave the one same number , MINE. so i undertook the work. bathroom was very large just short of 70m2 and the kitchen behind the propper aga cooker needed tiled aswell, just a mere 7m2.
pics:
after:
Concealed Wall Cabinet:
Tubbed adhesive is not the right choice for 400x250 tiles, its not the right choice for bathrooms or wet areas. As for you finding it a "pain in the bum" mixing cement based adhesive I cant understand that at all, it takes a few minutes and your using a far superior fixing method. When you say you don't exceed 3mm with dispersion adhesives, this picture looks more like 8mm and its not the correct way to fix tiles.
http://img.photobucket.com/albums/v688/v16ean/tling jobs/DSCN9117.jpg
I also insist on using the adhesive I know and trust, if they want cheaper stuff then I am not fixing them, simple.
not that i have to justify any of my work to anyone:
LOL......"not that i have to justify any of my work to anyone"
Love the work, as I have already said. The one thing that doesn't look right to me is the Aga area. Would have looked right without the picture or with a white gloss temp paint on the up pipe.
sean,i dont think anyones having a go at you mate,you have posted pics up of a number of jobs of which they look good when finished,
most of the questions directed at you have been about your adhesive choice mate and personally i would agree i wouldnt choose to use tubbed gear for some of the jobs you have done,,thats my own opinon though.
the point in the forum is for all off us to learn from each other and no one knows it all,so take it as constructive criticism mate:thumbsup: the end result your showing looks good
these are just a few of the tubbed adhesives thats supplied to customers for me to use when fixing tiles.
ok the tub in the pic is as follows granfix multifix.
quote from tub:
READY TO USE SELF PRIMING FLEXIBLE WALL TILE ADHESIVE FOR FIXING TILES SUCH AS PORCELAIN(whats the average size of a porc tile?)GLASS, FULLY VITRIFIED, MOSAICS, LARGE FORMAT, AND CERAMIC TILES IN DOMESTIC AND COMMERCIAL USE.
high adhesion strenth,conforms to BS en 12004, easy to use, grout after 24hrs, self priming no priming required, bed thickness upto 3mm, flexible for vibration and slight movent, waterproof for showers kitchens and bathrooms.
so really they are talking utter RUBBISH and its no good for anything.
Sovereign gold star:
sovereign gold star ceramic wall tile adhesive is a brilliant white, flexible, waterproof, non slip acrylic based emulsion based adhesive designed for todays PROFESSIONAL. goldstar can be used to fix all tile types including mosaic,marble,fully vitrified, glass, can be used on plaster,render,timber,over existing tiles:yikes:, and backer boards.
new plaster,render should be thoroughly dry before tiling and should be checked for plaster scum. dusty plaster,render should be brushed down and primed with 1:4 sovereign PVA/water solution or soveregin sbr/water when used in wet areas ie in a bathroom.
usual stuff aswell like a 3mm bed thickness.
Palace Superfix. as exactly the same as the above adhesives, also states that suitable for porc tiles upto 300x300 for tiles bigger than this it will take approx 2 days longer for it to set properly (does not say it cant be used for bigger tiles just it will prolong the drying time)
so basically you can understand that for shops giving out these products its a easy option to supply it for the everyday bathroom applications. although in folks oppinions on here they are completely wrong in what they are doing. what do you suggest then, i refuse to do any job at all thats linked to a tub adhesive?
You do instinctively know what's right for you. I was setting tiles to walls using BAL rapid set which has a very grainy feel to it. Cutting a fat story thin, I ran out but had some Uni Bond tubbed and the difference was huge. Much prefered using it and that speeded things up a lot. No complaints.
We all guarantee our work, thus soon learn what works. Each to their own..............
"One mans meat is another mans poison."
70m2 bathroom!!
Bathroom Tiling Advice
Unsolved
Sean fsy,
aqua blue,
Sean fsy,
aqua blue,
