A load of questions...
Z
zzr-matt
My bathroom is now finally ready for tiling!
The wall tiles are 230 x 400mm ceramic and the floor tiles are 300 x 300 ceramic.
There are a variety of surfaces and I have had the following recommendations for adhesives etc:
Walls which I've stripped back to bare plaster because they were painted with emulsion or had old tile adhesive on them. Prime with Mapei Primer G then use Mapei Keraflex Maxi
Boxing made of 9mm ply screwd to framework at 200mm centres. Mapei Keraflex Maxi.
Boxing in the shower area made of aquapanel screwed at 300mm centres. Tank with Mapegum WPS followed by Keraflex Maxi
Flooring is 18mm chipboard overlayed with 12mm ply screwed at 150mm centres. Consider tanking with Mapegum WPS Mapei Keraquick with Latex plus addative.
Does this all sound ok?
What size trowel shall I use for the floor and walls?
welcome 2 the forums
u have done ur home work
i would use a 12mm rounded tlowel on floor with flexi adhesive
calvy..
use 10mm floor trowel for wall aswell as you are using large format liles on wall. this will ensure 100% coverage on back of tile. do not use tub adhesive when using floor trowel, mix up some SPF, tub gear wont dry out quick enough.:thumbsup:
Cheers for the replies guys 😀
So if I use a trowel with 10mm x 10mm notches with a 10mm spacing for the floor and wall then I wont go far wrong?
How much of the previous tile residue do I need to remove? At the moment its stripped back but you can see some areas have a smidge of the previous adhesive left. I'd say its around 0.5mm thick or so? Worth stripping that off too?
I'd strip it off where you can. Consider using a decent trowel for the walls as those tiles are not small. You want 100% adhesive coverage throughout, meaning when you check the coverage as you're fixing them the adhesive should fully cover the back of the tile.... leaving no air pockets. (I think 80 - 100% is british standard for wet areas but I'd still go for 100 due to the tile size)
Can you clarify Matt, what this is referring to please... thanks
Hi what I meant was the trowel should have a notch that is 10mm wide and 10mm deep then a gap of 10mm then another notch 10mm wide and 10mm deep. I'm sure I saw a trowel somewhere that had 10mm wide and 10mm deep notches but only a 6mm gap between them.
zzr-matt,
DHTiling,
zzr-matt,
DHTiling,
