a quick way of getting battons on the wall
never used battens myself, always do the same as dave, battens are too slow
customer " oh dont you use battens"
Tiler " not really this way is quicker and far more accurate"
customer " i always use battens when i tile"
Tiler " yes so i've noticed"
customer "i've never heard of a tiler that does not use battens"
tiler " well you have now.....sir/madam"
customer " do you know what your doing"
tiler rings 999 " hello emergency services? can you send an ambulance to 1
smith street"?
999 " whats the problem please"?
tiler " my customer has somehow managed to get a 6 foot wooden batten trapped in his bottom.........sideways"
Got to batten when laying HEAVY tiles. My preference ,with lighter tiles,is to set the datum line at a height that will allow me to lay a course the full perimeter of the room(no battens). Can then tile down to the floor and then, as the datum row should have set ,can tile the top areas.
hi
if you are starting off and battens give you that bit of reassurance, then would rubi batten stands be a better alternative to glue guns etc??
ed
Those rubi batten stands can be a bit of a maul. A pile of tiles to hold up any droopy battens can help a dream.
hit tysfoot,its all done to experience friend, one day you will stop using battons because you will have a better understanding of tile adheshive, you will be more confident but it takes time
Start your first lower tiles and pin them up with masonary nails, after using an electrical gauge to source out the wires, copper pipes etc................
The right way start is to batten out...sorry guys but,I'm here to offer advice to new starters not pro's...go with battens and when you dont need them anymore,you have learned your trade well. It took me 4 yrs tiling (without help of any kind) to lose the batten.I'ts all about methods.Tile adhesive application,and choices of adhesive ,given time your action of applying adhesive will be good enough...until then go with what you are happy with,after all a batten will not do any harm....Gaz
Did my first batten-less wall yesterday....yipee.
Was only 150x150x5 white tiles and used White Star for the first time (good stuff, lovely to apply) and slapped tiles on to datum checked with a level and hey presto, no slippage.:thumbsup:
Grumpy
ryanbrown,
grumpygrouter,
ryanbrown,
grumpygrouter,
