Discuss Adhesive advice - tiles fallen from walls in the Canada Tile Advice area at TilersForums.com.
On one
Again......not defending the tiler, but it might just be that the 3 tiles that were replaced were dot&dabbed.......highly unlikely though!
The scenario could've been that all the tiler had in the back of the van on that day was ready mixed tubbed adhesive, but it doesn't take much to get hold of a bag of rapid adhesive.
Dumbo
Had same thoughts a you but you can see corner tiles which are grouted are fixed in same manner
SJPurdy
I have asked the owner but he has fobbed me off somewhat, blaming the tiles I bought.
Would you advise having ALL tiles in the bathroom removed? (even those on other walls, not around the bath, and floor??)
Why does the owner claim the tiles are to blame? IF there was something wrong with them why did they fix them?
If all the wall tiles are fixed in a similar way then surely they can all potentially fall off; therefore they should all be removed and then the tiling redone properly. If the bath has been damaged then this will make it easier/possible to replace as well.
As for the floor, if it looks good then ask for full details/specification of the preparation and fixing methods and post them here to get an opinion as to if this is correct.
K
Katie30
Might be an idea to ask the instalation company of a method statement of how they fixed the tiles
To add to the situation I've been told that the tiler who did the other half of the job has now been sacked..so I may not know what kind of a mess is behind those tiles unless they're removed
K
Katie30
Why is the tile below the missing one not grouted
I have noticed the grout between other tiles is starting to crack. Is this normal?
Reply to Adhesive advice - tiles fallen from walls in the Canada Tile Advice area at TilersForums.com
Hi am re tiling kitchen and want some ideas as to what’s best to repair the walls after Remiving...
This is the Number 1 Best Tile Adhesive from 2007 to 2021 recorded (almost) annually Discussion...
DIY Tiling; Advice for DIY Tilers So long story short, I have just purchased my first house and...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
