Thanks Dave. I really appreciate the reply. Any further tips I should be aware of with this kind of tile? I'm particularly concerned about the open cut edges. They'll be laid in brick bond and I'll tile right up to the ceiling with the shower enclosure to a projection along the 2 shower corner walls of about 850mm from the shower corner. The rest of the walls will be half tiled. So that will leave open edges on the 2 x 850mm projection parts if that makes sense. Should I lay it out such that the tiles which form the edges that run into the shower corner itself, and those at the other end of the projection are ALWAYS cut, so that they have a uniform thickness at those edges? Then use an 8mm tile trim to finish it off? I'm just concerned that if I don't do something of this kind, the edges will finish with alternate full thickness cut tile ends, and bevel edged tile ends which will be different thicknesses and will look odd when a trim is added to that scenario. Hope this makes sense and I guess the same question applies which tiling these into ANY corner. Thanks again.
