Discuss Adhesive not set after a week..... in the British & UK Tiling Forum area at TilersForums.com.
Mammamia
OK, thanks for the advice. I guess we'll have to learn the lesson and lift them.
Since they're stuck around the edges (and we'd like to re-use them if possible), should we hire an electrc tile remover (such as this one HSS Hire › Floor Tile Remover) or will this break them?
Also, is BAL rapidset adhesive with porcelbond plus in powder form the best option for adhesive (assuming we're still going to go over the top of the original tiles, which I would imagine will be a lot harder (and messier) to get up?)
Thanks very much for the advice so far.
Colour Republic
Yes, we have. We were also told that this would be OK as the existing floor is sound (concrete underneath the ceramic tiles). Is this not the case?
If nothing changes, will the adhesive never set? I now realise that it's not the best stuff, but ripping the whole thing up will be a big job for us.
I would have thought it would takes months (maybe never) for the adhesive to set, think of it like this, you got the adhesive out of a tub and you have effectively created another tub of the floor by sandwiching the adhesive between 2 non-porous materials
DHTiling
You have 2 surfaces and neither are absorbant..I am truly sorry to say but you have been advised wrong..That adhesive will never set as neither air can get in or moisture can get out via the joints or substrate...The tile is too large for the moisture to escape via the joint in a short time scale..it could take months to fully escape and even then if you have used more than 3mm or so in depth the tensile strength might not be enough to hold them down through lateral expansion of the different substrates.....
So IMO you have been very wrongly advised on the adhesive choice for those tiles...
If you look at this way....when the lid is on the tub of adhesive ..air cannot get in and cause it to set..so by using such a large tile you have in theory put the lid on, if you see what i mean...Dispersion adhesives like that are not designed for you have used it for..
Mammamia
Cant find teh spec on this adhesive (funny that eh ?) does it say suitable for Porcelain?
It's this one Broken Link Removed
The chap in the shop said it would be OK to use (we were very clear that we were putting porcelain on top of ceramic tiles) and he said it would just take a bit longer to dry. The sad part is we have spent more than £200 on the adhesive alone....
Colour Republic
You have 2 surfaces and neither are absorbant..If you look at this way....when the lid is on the tub of adhesive ..air cannot get in and cause it to set..so by using such a large tile you have in theory put the lid on, if you see what i mean...Dispersion adhesives like that are not designed for you have used it for..
You're going to have to get up earlier than that Dave:prrr::lol:
Colour Republic
It's this one UniBond Tiling On Concrete Floors Adhesive & Grout Extra Strong Beige 4.6L, 5010383131401
Did you but the adhesive from B&Q? The staff (in general) are not really qualified to advise you in such a way.
I would have thought that if you complain about the advice given, you would get some form of compensation
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
You should find they'll come up quite easy.
And I'd use a Mapei product which you'll find much cheaper than BAL. And Mapei are the world's largest manufacture of building materials in the world. You can get it from any www.TileGiant.co.uk store.
craig4749
Even the description on there website shows it wont do the job
"UniBond tiling on concrete floors is a high strength tile adhesive and grout specially formulated to tile directly onto concrete and screed floors. Waterproof and ready to use, it is suitable for fixing and grouting ceramic and quarry tiles"
You are tiling onto tiles and using porcelain tiles, got those people make me mad!!!:mad2:
DHTiling
Mammamia
Yes we did, and lesson learned. We did have a tiler lined up for this but he let us down five times since June - we got a little annoyed and just thought "we'll do it ourselves".:yikes:
Will go back tomorrow and see what they will do, if anything.
I really appreciate the kind responses so far, as you can imagine we're pretty down at the moment and this really helps - 2 last questions please?
Should we hire the tile remover with a view to being able to re-use the tiles (the tiles are stuck down around the edges quite firmly and there are over 100 down), and is the BAL adhesive the best option? (Edit, I was typing this as Dave posted his comment about Mapei - thank you).
Many thanks,
MM
Gazzer
You wont need a tile remover just a bit of effort with a stiff blade and Mapei would be my choice of adhesive.
Please give B&Q hell for their absurd advice.
I woould also contact Unibond and ask them if this adhesive is suitable for you job. If they say no, which i believe they will, i would then challenge B&Q with this information.
Reply to Adhesive not set after a week..... in the British & UK Tiling Forum area at TilersForums.com
    • Agree
    • Informative
Is the issue with ready mixed adhesive seemingly only recommended for 30x30 tiles max that it...
Hi I have just had my wet room tiled and after one use the cream coloured grout has gone black...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
