PaddyW
Running out of options.
I would be grateful for some advice regarding a bathroom refurbishment in Spain. The property is not used for long parts of the year and I have problems of damp and condensation. It has always been difficulty to know whether the flaky walls and salt are caused by damp or rising damp. At the time the house was built (2004), Spanish builders infrequently used damp proof courses. The problem started after 5 years. After years of problems I had a new injected damp proof course installed, air vents installed in every room and a PIV system installed (Flatmaster 2000 | The Complete Ventilation Solution | Nuaire - https://www.nuaire.co.uk/residential/positive-input-ventilation-piv/flatmaster-2000). The PIV system runs 24/7. The walls were replastered by a British company and repainted. Eighteen months later some of the walls near the floor were all flaking again, and salt deposits were on the grout on some of the floor tiles.
This property was to be my retirement home, but I get depressed every time I walk in the door and see the state of the walls and floor despite all the money spent on getting it to look nice.
In the bathroom there has always been some salt in places on the grout. The grout at the moment is about 0.75cm wide. The bathroom is to be completely gutted and new wall and floor tiles laid, and new drainage put in place. I want to ensure that the bathroom has been sealed properly to avoid salt on the tile grout or any other form of rising damp. The builder and tiler have suggested using Gunite which they use to seal swimming pools. The new floor tiles will be pretty close and I don’t know how much grouting will be done this time round.
Any advice on how best to proceed would be gratefully appreciated. I know that products are different in Spain and this may be part of the problem in resolving this problem.
The salt on the grout in other parts of the property is significant but scattered and intermittent but there were small piles about 0.5cm high. Could this grout be raked out and redone to prevent this happening again? Any recommendations on the type of grout or sealant to be used? I should add that the same type of tiles are used on the patio surrounding the property and I have never seen salt outside the house.
I would be very grateful if I could draw on the expertise of users of this forum as I seem to be running out of options.
Thank you
PaddyW
Thank you
PaddyW
